Question about the Logitech Z-5500
Blauman
I am thinking of getting these to watch DVD's and to play Xbox and PS2 games. Its not going to be hooked up to a PC as I already have the Logitechs that are one step below these. Im just wondering if anyone has used these as a psuedo home theater setup. I dont really want to drop the cash right now on a whole 5.1 setup when these will probally work just fine for the time being. Thanks for any replies.
Well, I had the z-680's hooked up to my ps2 and I played Gran Turismo 4 on them. It was pretty cool, to bad the speakers were'nt setup right..But imo I don't think its worth buying another 5.1 setup for.
Well the 5500 series is a minor upgrade of the 680, the 5500 adds a facelift a couple of added inputs and a bigger sub, but i believe the the sub still has the same output as the sub for the 680.
But I use my 680 as a theater setup, and it's great as long as you can place your speakers like they should be, and when I am not using my XBOX or PS2 I unplug the optical and connect it to my computer
I have a TV cabinet that is about 7 feet wide and I would put them on the sides of that and put the center channel on the top of the cabinet and run the rears about 10 feet to the couch and put those on either side of the couch. It should work just fine except I need to figure out what to do about the wires :) since I really dont have a clean way to run them to the couch.
