Question about the "Innovatek PCPS" pump.
Wilson123
Hello!
I'm going to build a watercooled mini-ITX system in the near future (the only thing ive been waiting for is the Intel G3 SSD´s and they are arriving soon) with the Sugo 05 as chassi. I have yet to decide on what pump i should use tho, i'm extremly limited to choices here since there is so little room in the chassi. However, I have found a pump that would fit if my math is correct but it seems to have shitty performance :(
So my question is: Will the "Innovatek PCPS" be able to power a loop that consists of 1GPU, 1CPU and 1 120mm radiator?
And how would the temps be? Would it be possible to overclock?
Thanks in advance :D
Of course it can...but can't be sure about the temps....you see different CPUs and GPUs consume and disipate different ammounts of heat
