Question about the Corsair H70
wolfofone
Hey guys, I'm wanting to get the H70 to improve the temps in my build; however, I would need to mount the rad/fans on the front of my case as the rear and top exhausts are only 80mm. How long is the tubing on the H70? My case is the Lian Li PC-60B iirc and I'm not using the bottom hard drive cage (it's not even installed in my case). Do you think the tubes would be long enough, or should I just look at a big air cooler? Thanks in advance!
the tubing on the h70 is 9in the h50 has 12in of tubing. if you can fit a h50/70 there nice little units are about = to high end air depending on what fans you use
Thanks for the info thax, I wasn't able to find it as my google-fu was failing me this early in the morning :p
I'll have to do some measurements :)
