No.Is the bass good enough for games, movies, and loud music?
For gaming, movies, and if you listen to and electronic or hip/hop music, then I definitely recommend either larger speakers, or a subwoofer to go along with them.Do you want to go into more detail?
Also, how do you propose to add the subwoofer to the system? Directly to the sound card?>
I find the bass on my A2's to be adequate. It really just depends on what your expectations are. They definitely are not bassless, but they aren't going to produce bass like a sub would. I listen to movies, games, and music and for all three categories the A2's work and sound great.
I don't have A2's, but the A5 can give response to about 50hz. That will cover mid bass, but you will not get the 'shaking' or the 'rumbling' that come with explosions. That's the 30hz-50hz range.
Ah. I'll get the speakers first. If I feel I need more bass, then I'll get the sub. I am 99% sure I have everything worked out. Now the last step is to just get the money for the purchase.
Well, I would say anything lower than 50Hz... below 30Hz will be more vibration of surroundings than sound (which is basically rumbling that you can feel rather than hear).
