cannondale06
- Nov 27, 2007
I was looking at HD Tune and was wondering if that 100mb partition is supposed to show 0% usage.
gif upload
gif upload
yes I re installed it but I thought I deleted what I was supposed to. it only showed the one 930mb part when I started the actual Windows install.I bet you have reinstalled the OS at one time on the drive without deleting the partitions? Are your bootmgr and bootsect.bak files (hidden) on your C:\ drive? They should be in that 100MB partition.
When you install you typically delete even the partitions available so all that is shown as unallocated space, click that, then next. That would allow Windows to properly create and use the partitions.yes I re installed it but I thought I deleted what I was supposed to. it only showed the one 930mb part when I started the actual Windows install.
does it hurt anything to have it like it is right now? and how do I see if those files are on my C drive?
well I thought that is what I did before i clicked next because it only showed the one thing which was the drive with unallocated space.When you install you typically delete even the partitions available so all that is shown as unallocated space, click that, then next. That would allow Windows to properly create and use the partitions.
To see the files, open Windows Explorer, click on C:\, then press Organize-> Folder and Search Options. Uncheck hide hidden files and uncheck hide operating system files. You should see the files I listed.
yes I now think that is simply the issue. I was just looking at hdtune for my temps and noticed it said that so I was worried I had done something wrong. after later looking at disk management though it appears everything is in order.hdtune might not have the ability to read partitions that don't have a drive letter correctly. Just a guess. I'm not sure if it has the hidden tag on it or not...
as long as disk management shows the correct thing then I am good.You could apply a drive letter to it & see if hdtune can read it correctly.
