Question about SSD alignment
SigmaOrionis
I just picked up a Crucial M4 256GB today.:)
I did a fresh install of Win 7. I verified that Trim was working and that the alignment is correct.
I usually after a fresh install, before I install a bunch of software do a clone to an external drive. So if I ever want to go back to ground zero it only takes about a half hour.
My question is with an SSD is cloning to an external USB drive gonna mess up the alignment when I restore back to the SSD.
Anybody that has any experience with this I would appreciate your insight. So I dont have to do this time consuming experiment myself:p
Thanks.
As long as you use a reasonably up to date cloning app, it will be ssd aware and do the proper alignment.
It would seem more logical to make the clone AFTER installing a bunch of software, installing windows is pretty quick.
Cloned my laptops harddrive to a SSD with acronis 2011 home edition, worked fine, aligned and everything. I had the SSD in an external enclosure and encountered no difficulties that weren't caused by my own lack of experience. Nothing fatal, anyway.
Thanks for the answers.
Aesma, not as fast as restoring off a clone with all my drivers ready to go. I also keep a running backup about once a month.
Thanks again.
