Well i'm not 100% sure where to post this, but i figured it's a tool for testing overclocking so good enough right?
Well i decided to check out SP2004 and i like the interface alot better than prime 95, it seems to take all the normal tasks and put it right there in an easy to read manor.
Here is my issue, im using clockgen to try and find what my chip is going to do, but when i raise up the HTT SP2004 does not show a change in my CPU speed, even though CPU-Z does. Do i have to set each clock via the bios just to use this program?
Have i done something wrong?
