Question About SLI
TheoV
Well thats the system i've ordered and most os the parts have arrived.
AMD ATHLON 64 4400+ X2
2 GB GSKILL 4000BSU
DFI LP NF4 SLI-DR
THERMALTAKE ARMOR
THERMALTAKE PSU 680 WATT
2 X EVGA 7800 GTX
MONITOR PHILIPS 19"
The question is
Should i drop 1 7800GTX?
My monitor is 19" as said above.I will have a good performance in high resolutions but is it worth it.
Thanx
It will be later on yes.. as of now, 1 7800GTX should be able to run everything fast enough to game 40+FPS.
I say buy one now, then when you really need it buy another. By then they will be a lot cheaper. :)
You don't really need 2 with that monitor.
What's your max resolution, 1600x1200?
My max resolution is 1920x1440.
What should i do both of them arrive in three days.
The second will not help at all at high res.
