Question about SLI using cards with differing onboard memory
sboarder1
I am currently running a single EVGA 8800GTS 320MB graphics card, with two monitors (22" and 23") hooked up to it. I just got a third monitor (24") that I want to add. Therefore, I plan on going SLi with the setup.
I'm looking at getting a 8800GTS 640MB as the second card. My first question is, can I run an 8800GTS 640MB with the 8800GTS 320MB? Would I get any benefit with getting the 640MB version, or would it only utilize 320MB of it so it matches the current 320MB card.
My second question is, is a 550W power supply (Rosewill) enough to power two 8800GTS cards in SLi? That's the power supply I'm currently using for the single 8800GTS, but I'm not sure if I need to get something with more power for the SLI setup.
I would be worried for 2 reasons.
First, you can not run 3 monitors in a SLI config without a TripleHead2Go. SLI disables the 2nd cards video ports.
Second, I'd imagine you might just nuke that PSU, but without exact model, can't say for sure.
sli will work and your exactly right, it will only use 320mb of the memory.
traze is also correct that you can run 3 monitors with sli. as of now you cant even do dual monitor with sli, but nvidia is releasing a driver soon that should add that.
the psu im kind of iffy about, some rosewills are good and some are very poor.
