Hi folks, i've got a dual AIO water cooled system (gtx680, i7920)
So... at the rear of the case (550d) i've got a corsair h80i in push/pull exhausting out the back of the case.
At the front of the case, i've got an Antec h20 620 cooling the GPU with push/pull fans bolted to the radiator. In order to make this AIO kit reach, i had to install a couple gutted fans between the front of the case and the push fan.
Like so: <fan<[rad]<fan<shroud<shroud<case< (< airflow)
would moving the push fan like this: <fan<[rad]<shroud<fan<shroud<case<
1. better cooling?
2. a little less noise?
The 'shrouds' are gutted 25mm thick fans.
Assuming this would be of benefit, i can only assume modifying the case further to accomodate shrouding as such would be ideal:
<fan<shroud<[rad]<shroud<fan<shroud<case<
whew, that's a lot of <
Thanks for any input ya'll can provide.
Secondarily, as i think it will be much trickier to work on, are thin shrouds of any benefit for noise? like 7mm thick? i'm thinking of shrouding the h80i on both sides, so the fan isnt smushed right against it. dual 25mm shrouds would be so thick, the h80i pump would be covered completely !
1. better cooling?
