dambrosioj
- Sep 7, 2005
I am looking to setup a new eyefinity setup and it looks from reading that because there is not 3 similar outputs you will see tearing
would a card like this new asus
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121431&cm_re=6950-_-14-121-431-_-Product
with 4 display ports solve this problem? also would I be able to by a DP to DVI adapter and have them work the same way if i did 3 DP to DVI adapters?
