Is there a place that sells a molex to SATA power adaptar that does a Y split into 2 SATA connectors?
I already have an 80gb SATA drive in my system, it has a standard molex connector as well as the newer SATA power connector on it. It is currently using the molex power connector as that is all my power supply has.
I went out and purchased a Maxtor SATA 250gb 16mb cache drive but I didn't look at the power connector on it. Turns out all it has is the new SATA power connector and not a molex one. I have no spare molex connectors in my system anyways.
Since I have no spare molex connections, it would be nice if I could find a molex to SATA x2 connector so that I can power both drives off the same cable but I haven't been able to find any place that supplies them (I heard they exist though). Anyone have any ideas on this? The only other option i could think of is to buy a standard molex Y split adapter, then get a single molex to sata adapter to put on one end for the new HD while keeping the older drive on the molex connector.
