VirtualBox leaves no trace of itself when it's not in operation: when it's closed, it's closed. Period.
If you don't need 4 unnecessary services running constantly even when VMWare isn't running; if you don't need the bloat of VMWare overall (huge download, even more space consumed after the installation); if you don't need any possible 3D support for any reason in the virtual machine you're planning to run; if you want something fast, lean, and totally useful...
Then VMWare isn't the choice. VirtualBox is.
If you only intend to do the most basic stuff most people do with XP (no gaming, no hardcore stuff, but you want to run XP for some compatibility issues or whatever), then VirtualPC 2007 would actually be my recommendation. Just for running XP for the basics, it really does a great job.
But personally, I'm a huge fan of VirtualBox these days. It's very lean, it's very fast, and takes up very little space by itself. If you have a processor with VT-x support then VirtualBox can be configured to use that and the benefit will be a virtual machine that operates at near-native installation speeds - VirtualPC 2007 doesn't have that support. VMWare does, however, but again, you end up with a lot of code bloat and the 4 services running constantly.
So VirtualBox gets my recommendation for just running XP inside Vista.
sounds good, can that Virtual Box run linux too?
I just don't see how running Vista + VNWare + XP > Vista
I'll give you an example. I run Vista Business as my primary OS, but I run XP Pro SP3 in a VM, for troubleshooting any issues my users might have. This way, I can quickly boot into the same environment as them, without having to reboot my main system. I also keep a clean Vista VM to try out some new freeware, before installing it on my main system, such as when I tried several free burning apps, to see what I liked.I just don't see how running Vista + VNWare + XP > Vista
