Apr 13, 2008 #1 K kevinf Limp Gawd Joined Feb 21, 2004 Messages 375 i am about to reformat my computer and i need to know if there is a way to export my fan settings from rivatuner and import it into the new installation
Apr 13, 2008 #2 N NKDietrich Supreme [H]ardness Joined Jul 25, 2004 Messages 5,442 Write them down? Thats probably what I'd do.
Apr 14, 2008 #3 W W.O.T. Stang Limp Gawd Joined Aug 4, 2003 Messages 363 Since were on the subject... is there a way to set rivatuner to auto control the fan speed to the temperature of the card? Like below 40% below an idle temp, then 70% after an average temp, and 100% if it drops above a high threshold? I know the card itself does this, but im not comfortable with 80ºc as the high range temperature the card defaults too.
Apr 14, 2008 #4 T TopGun Gawd Joined Jan 22, 2005 Messages 766 I think you can edit the threshold if you go into the "low level fan settings".
