Question about Rivatuner (using with GTX 280)
DeadByDawn
I am trying to use Riva tuner to prevent my gtx 280 from downclocking.
I did the following:
1) install and run rivatuner.
2) got to the poweruser tab
3) goto Rivatuner\Nvidia\Overclocking
4) Set EnablePerfLevelForcing = 1.
5) Hit "OK"
If i hit ok and close the riva app, is it still running?
Do you need to run it every time you boot windows?
Are there any other steps i need to take?
I thought it was ok, but it downclocked in a game i was playing.
The goal is to keep my 280 from downclocking (a known issue with some of them).
Any other suggestions?
Thanks
Did you follow the steps listed here?
GTX 280 Downclocking and/or Throttling?
There is a temporary solution.Use rivetuner And select "Force Constant Performance Level" and set it to Performance 3D And your set.To enable this setting go to the"Power User" tab and set RivaTuner\Nvidia\Overclocking > ENABLEPERFLEVELFORCING and set to 1.
Thankfully my 280s didn't suffer this.(returned for refund and re-ordered cheaper :p) I'll have two new ones next week to check out. :)
I did follow that exact thread. It seemed to work, but then it happend again.
Need to understand more about RivaTuner.
Ho can i tell its working?
