Ok, long story straight, I'm picking up some water cooling stuff from a local guy. I'm getting a XSPC RX360 for $10 which is pretty swell. The only thing though is he says there are holes in some of the fins because when he attached the fans he used screws that were too long. I don't know anything about the flow path of water on water cooling radiators, but is there any chance that he somehow punctured it so that it leaks? Or did he just ram screws between the fins? I tried to get an explanation from the guy but it he wasn't really clear. He mentioned maybe using jb weld which got me thinking.
So long story straight, if you took a RX360 and screwed long screws through it, what would happen?
