So I understand how PWM fans work etc. etc.
Since PWM fans were designed to be compatible with this method of control, is it safe to assume that it will react nicely wne used with a controler that only has a 3 pin connector but uses PWM to control the speed of the fan?
To be more clear.
I will not be using the 4th pin on the fan connector (PWM Signal) and only the first three. (gnd, 12, rpm) So the internal circuitry in the fan that regulated the speed according to the PWM signal is not used. Will this fan run without the "growl" associated with non-PWM fans?
-Brian
To be more clear.
-Brian
