Question About PSU connectors
Drakonus
Hi, Im building a system in the nesr future, and i was just going to take the PSU from my current piece of crap and put into my new hotness. anyhow, im reading that some motherboards require a 24 pin connector and some require a 20 pin connector. Im planning on getting the MSI K8N Neo2 Platinum. Does anyone know if this is a 24 or 20 pin connector? and how do i find out what kind of connector my PSU has (Other than disconnecting it and counting the pins hehe)?
I'm pretty sure that the board you are looking at uses a 20-pin connector. The PSU that you have, is it 1)bought in the last year? 2) Very high quality (watts don't mean jack) ?
If yer not sure, just count one row of the pins and multiply it out.
The cool thing is that the 24 pin PSUs will work with 20 pin mobo's, but you'll just have to 1) line up the pins differently leaving 6 pins off or use a 24-20 pin converter that is usually provided by the PSU manufacturer.
