three4seven
- Oct 11, 2004
I apologize in advance if this is a trivial question -
When overclocking, is the CPU power consumption correlated to the clock speed, the voltage, or both (or .. something else)?
For example -
Will a "good batch" i7 running 4ghz @ 1.25v draw less power than another i7 that's running at the same clock (4ghz) running @ 1.35v?
I'm guessing so.. how does one calculate the difference in power draw? Is there a significant difference in power draw?
Will bumping up the frequency to 4.2ghz but keeping the voltage the same equate to the same power draw as when the CPU was clocked at 4ghz?
Thanks in advance for any input.
For example -
