Question about PCI Express bus speed
jchen012
First off, I have a P5W DH. I recently got a RAM cooler from OCZ. However I couldn't install it since my video card was in the way. So I moved my video card to the 2nd PCIe slot. Now in ATI CCC, it shows my bus speed as x8. Is this normal? How can I make it x16. From what I've heard, you can have one x1 and one x16 or two x8 (if in Crossfire). So how do I force my motherboard to change the first PCIe slot to x1 and the second slot (with my current video card) to x16? Is it in the BIOS? Any help would be appreciated. Thanks.
I don't think you can, slot 1 is in 16X and if you put someting in slot 2 I think it automaticly become 8x / 8x there's noting you can do I assume. most likely there's not even the full 16x lines on slot 2.
Will my graphics performace be greatly effected on if I stay on the x8 bus? Or should I move it back to x16? I have a x1900xt.
It should not affect the performance too much, I would not worry about it. Theres a budget board for Core 2 duo that actualy only have a 4x PCI-Express slot for the video card and the performance loss is like 5 to 10 percent so a 8x should be even less.
This guy even got a performance increase hehe: http://forums.tweakguides.com/showthread.php?t=4040
