jadawgis732
- Jun 18, 2009
So I reworked my build over the past few days, and installed some bitspower crystal links. Two questions: is this what galvanic corrosion looks like? It seems like the nickel plating is peeling away to reveal copper underneath. Yet another testament to why you should only use distilled+kill coil.
Second question has to do with parallel flow. Does it only work if you have the flow going against gravity? Because after playing CODBLOPS for less than 5 minutes the temps on the two GPUs were 90/45 before they were about 51/53 (flow was more restrictive on the loop). Still I think it's clear from the temps on this setup, that parallel flow is NOT working the way it should be. Thanks for the help.
