Question About P4 s775
GooG
My CPU is a P4 519.
It has some wierd attributes, but i wanted to know if a mobo supports a 519k will it support a 519.
This is the comparisons of 519 to 519k
519
Processor Specifications:
sSpec Number: SL87L
CPU Speed: 3.06 GHz
PCG: 04A
Bus Speed: 533 MHz
Bus/Core Ratio: 23
L2 Cache Size: 1 MB
L2 Cache Speed: 3.06 GHz
Package Type: LGA 775
Manufacturing Technology: 90 nm
Core Stepping: E0
CPUID String: 0F41h
Thermal Design Power: 84W
Thermal Specification: 67.7°C
Core Voltage: 1.25V-1.388V
Supported Features:
Enhanced Halt State (C1E)
Execute Disable Bit 1
Intel® Thermal Monitor 2
519k
sSpec Number: SL8JA
CPU Speed: 3.06 GHz
PCG: 04A
Bus Speed: 533 MHz
Bus/Core Ratio: 23.3
L2 Cache Size: 1 MB
Core Stepping: E0
CPUID String: 0F41h
Core Voltage: 1.25V-1.400V
Supported Features:
Intel® EM64T 2
only differnces i see is core voltage is higher on 519k
intel EM64t2 is enabled on 519k.
So would a 519 work in a 519k board?
