Question about overclocking Shuttle SFF
I was planning on keeping the memory that came with it. I just want a little boost if possible, I don't want to be spending more money if I can avoid it.
ThomasE66 said:
The only way to find out is the usual way. Up the speed a little, test. Lather, rinse, repeat. Go for the HyperX memory option rather than generic.
HyperX 3200 doesn't overclock that well! :( I found out when I got some cheap from outpost.com :mad:
You will need to make one mod. Trust me, its worth it!!
Cut the back fan guard off. It restricts the airflow WAY TOO MUCH!!
More (minor) mods here, if you get some balls.
Will cutting that hole make the machine any quieter??
What did you use to cut it?
