okay I am at 525/1363 and riva tuner is reporting "internal test failed" when I hit test if I go anything above these two numbers. But when I run 3dmark2k5 at these numbers I see no artifacts....so can my card go higher? Is this a riva tuner drive problem or is it something that can protect my graphx card?
My 7800GTX has a fan mod and at the above overclock I am getting 58 degrees Load(which is pretty low considering it was 72 degrees load at stock prior to the mod).
