Question about Nokia 445pro, maybe monitors in general.
Tetracell
A friend of mine gave me his Nokia 445pro the other day because I was interested in buying it from him. After having it hooked up for a bit, I notice that at the right and left corners of the screen on the top and bottom that the screen is a bit fuzzier than around the center of the monitor. It's also apparent on the left and right edges themselves, but it's not as bad as in the corners. I was wondering if something like this is normal because of the size of the monitor, or just the way it's made, or if it's not can it be fixed?
It's normal for CRT monitors, dot pitch is measured from the center and usually increases towards the edges. My Samsung 950p does the same thing. Look for something called iiyama monitor test and tweak around with the sharpness settings until it looks better to you. The corners will always be more blurry than the center though.
