Question about new Tagan
sasquatch
I just got my new PSU: Tagan Series 480W Power Supply, Model "TG-480"
It has a seperate RTN grounding cable, and i'm not too sure what exactly to do with it. It tells me to "connect the RTN GOURNDING CABLE connector (a thick cable) on one of the fixing screw-holes of your mainboard (the RTN/GND connections", but what exactly does that mean. An answer ASAP would be nice. Thanks.
Just attach it to any screw within range if you have an all-metal case.
If you have an acrylic case, just snip it off!
