Question about new Mountain Mods Case
gilga
I am looking to get a new case soon and have been racking my brain on deciding which one. I am looking for great air cooling capabilities but with ability to easily add an internal WC loop later. Lastly it has to have pass through holes for my nautilus. Long list of requirements. I thought I may be out of luck, until I saw this
http://www.mountainmods.com/h2go-aluminum-cube-computer-case-p-414.html
Can you please tell me if Mountain mods cases are any good, and if this one will be decent. Thanx for the input!
anyone out there have an opinion. If the mountain mods case is any good, I would like to get my pre order in to receive the discount
Well they are the best cases on the market for what they are intended to do. Mine does great, and has a bit more room for some water later.
That case is nice, I would get it but it is to small for me. It looks like it will work perfect for you. But you might want to email them asking what size those rear holes are.... Could be to small, but i doubt it because your Nautilus has 3/8 tubing correct?
They make great cases, but the only thing I hate about them is their paint job, mine has the orange peel to it, I will have to get it fixed sooner or later..
