question about my oc'ed 2500m...
thenerd
1. why does my 3dmark 2003 mark rise by only 15ish points after oc'ing from 2.2ghz to 2.4ghz?
2. i can't seem to oc the fsb over 200... if i get it at 200, then the comp over fsbs it to 200.5 in windows, which basically oc's my generic 3200ram... so as a result, i am not able to last even 5 minutes in prime. yes, i have tried upping my vcore to 2.7 instead of 2.6 - does this have anything to do with that divider thingy? cause i don't have that option avaliable in my bios, A7N8X-E deluxe, but i do have that ram percentage thingy, which i currently have set at 100%.
*vdimm.... jeesh, my vcore is at stock 1.575 :p
and, no i don't think i'm running a divider, at least i can't find such an option in the bios. as i have mentioned before, i do see a percentage setting which adjusts the ram speeds. i have it set at 100% right now.
yup, no difference if i set my vcore to 1.725 instead of stock. i doubt thats the problem anyways, since the problem manifests itself when i get 2.2 ghz stable, or 2.3ish stable.
If you can't get over 200FSB, I'd have to say you have the worst PC3200 on Earth.
Pick up some Corsair or whatever is hot with the kids nowadays. ;)
i have the same motherboard and when i push my 2500+ to 200mhz fsb its gets all unstable. It doesn't seem to matter what settings my ddr is at, it just doesn't work. I run it at 190mhz now, because its stable and much cooler temps.
Have you done anything to increase the mobo chipset cooling? Does it come with a fan?
If you mobo has the option increase your vdimm to 2.8 or 2.9.
