Question about my Nforce2 drivers for IDE
Birdsontop
Is it better to use the Nforce2 IDE controller drivers or just use the drivers that come in Windows? Does it make a big difference? Thanks.
My system specs:
Asus A7N8X-E Deluxe mobo
AthlonXP 3200+ CPU
1gig PC3200 RAM (512 X 2)
Maxtor 80gig & 120gig 7200/8mb cache
BFG 6800 Ultra OC
SB Audigy 2 soundcard
MSI 52X32X52 CD-RW
Plextor PX-708A DVD-RW
Viewsonic A91F+ monitor
Klipsh Pro Media 2.1 speakers
I would suggest not using them. I had issues with my specific DVD burner when I had an Nforce2 board (A7N8X 2.0 non deluxe) and I was force to uninstall them and use the Windows drivers. Everything worked without issue after doing so, and I noticed zero performance difference.
