northfaceseen
- Dec 28, 2011
Hey,
I got a EVGA GTX 690 last week and I have noticed the one of my gpu cores GPU 1 runs about 8-9C higher than GPU 2. I have checked the paste on both cores and applied Phobia Grease and I also checked to see if my case flow was obstructing my gpu fan flow, but my cores are still very far apart on temps. From what I have tested if I block airflow from flowing out of the front of the card my GPU 2 temps rise, so I am thinking GPU 1 is the core closest to the I/O panel. My question is, is it normal to have such a wide degree difference between cores if the heatsinks are making proper contact and the gpu fan flow is unobstructed, and would I have a just case in RMA'ing this card?
Thanks for your guys input
