Question about my 12v 4pin
lil layzie
I bought a new corsair psu (CX430) to power my old amd64 system.
My motherboard is an DFI Lanparty UT nF3 250GB.
The problem with this power supply is it doesn't have a 4pin 12v wire to connect to my mobo. I just wanted to see if my comp would still power up and it did.
Here's the top half diagram of my mobo
Where the red arrow is pointing is where I dont have anything connected to it.
Since my computer still turned on without the connector, is it safe to run the comp without it? or should i just go and get something like a molex to p4 adapter?
If you look at the 8-pin EPS connector, it should split in two to make the connector you need.
lol ok I'm an idiot, i didn't realize the eps connector split like that.
i turned off my comp to check the connector and it was able to be snapped off to fit into the p4 connection.
i guess i was just excited to connect my new psu to my comp overlooking that small detail.
