Well, the MXM standard defines the cooler mounting layout already, basically all MXM cards have the GPU die and mounting holes in the same place so that the coolers are universal.
With that being said, if your laptop already has an MXM 3.0(a or b) card, the cooler you have will work with any other MXM 3.0b card. If you don't already have a card and plan on adding one, then you would need to find the stock GPU cooler assembly for your laptop.
um.. doesn't your laptop have the A8-3500m/6620m ? that laptop doesn't have a mxm card slot...
It does contain a slot, I noticed it when I replaced the stock thermal paste on the CPU.
Look around for other gateway models with the same chassis design as yours with a dedicated GPU, then lookup the parts on ebay and see if you can find the GPU cooler for it.
Gateway will make a lot of different models of the same chassis with each one having its own model number and some of the time the components are compatible.
Gotcha. Just noticed that it's actually a MXM 3.0a slot, not b.
http://www.ebay.com/itm/ATI-HD-6600...805?pt=PCC_Video_TV_Cards&hash=item1c211cbcfd
I'd love to have one of those, but no way in hell for that price.
