Jeffredo
- Aug 30, 2008
I've never Crossfired or SLI'd GPUs before, but am considering it. I have a Crossfire motherboard and HD 6870 cards are often pretty inexpensive now. I read this article on Tom's Hardware about the problem:
http://www.tomshardware.com/reviews/radeon-geforce-stutter-crossfire,2995-5.html
The FPS dips are pretty bad with both systems (although X-fire is worse). My question is if you only have a 60 Hz monitor, use vertical sync and your multi-GPU setup is capable of pushing over 100 FPS, would you experience any microstutter? I was thinking since its capped at 60 FPS nothing would happen.
