question about mounting side fans
I have a sniper right, and on the side panel there are holes 2 mount 2 fans... I'd like to mount 4 so how would that be possible? I tried double sided tape and that didnt work at all.. thanks
lolwut?
Can you show us a pic of what on earth you are talking about?
Drill new holes?
the sniper comes with holes on the side panel to mount 2 fans.. there arent enough holes to mount, 4, so yeah I'd like to know how I can mount another 2
If you're talking about mounting 2 fans in one spot then I suppose you could take some screws used to bolt the first set of fans to the case and use those screws to mount the second fan on top of the first.
No, much like the stacker 830 I want to be able to mount 4 fans onto the side panel... no one has any ideas?
2lbs test fishing string, if you want to get crazy use some spider wire.
Well mate, cut a couple more holes in the side of the thing and zip-tie a couple more fans on...
But I'd cut a hole in anything me...
My PC is screwed to a piece of plywood on the wall....
EDIT:
Please don't cut holes in your CM Sniper
