Question about mounting PM 5.1...
jamezzz122
Well I was planning on getting some Promedia 5.1 Ultras and I would need to mount them on my walls...
How did you guys do it or what would you suggest?
you something something like this ?
if so, I wouldnt think making something like that would be a hard thing at all. you'd just need some pieces of metal like whats in that pic and bend them to a 90 degree angle.
then drill the holes to mount the screw to the speaker and the two holes for the wall.
that kind of looks like something you could make on a lazy day with about $20 worth of material including some black spray paint.
Yeah that is exactly what I was looking for...I would make them but I am pretty unskillful at fabricating stuff like that..
