question about modding antec p180 or p150
picobrain
Considering a new case antec p180 or p150 for computer.
I have an old pci card that i MUST use in the new system, but it's 11inches long,
and per antec will not fit in a stock case.
Can anyone with one of these cases see if it would be simple
to modify either of these cases to fit such a long card.
Dremel available.
Thank you
what card do you have that is that damn big?
if you let it go into the second hard drive bay it could fit...maybe.
this old Gadget Labs Wave/824,
http://www.gadgetlabs.org/
from a few years ago,
it's too good to replace on my small budget.
ps: how about the p160?
Thanks
hey, good ol' Gadget Labs! what kinda audio/music you doin', if you don't mind my askin'?
i checked my P160: i just measured from the point at which the card would extend into the case, and i have exactly 11 3/16" to the drive bays.
if that card were precisely 11" long, i'd say you'd just fit by the skin o' yer teeth... but given that there may be some variances between cases within the same model, you might be taking a chance. worse came to worse, you could always take some tin snips and cut out the offending drive bay.
i'm not a big-city lawyer or anything ("GASP!"), but doesn't someone make an external "PCI bay" or something? seems just crazy enough to exist; maybe it wouldn't be too expensive. anyway, that's just crazy-talk.
hope this helps (or at the very least, doesn't confuse)!
