Question about Mobo and CPU. system is running
4LC4PON3
DERP!
ok i got my system up and running today and im not sure if this is an issue or not. when i boot up the PC it sais This CPU is not supported by This Motherboard then gives me an asus website to go to.
Running C3 955 BE and the board is this ASUS M4A78LT-M LE AM3 AMD 780L Micro ATX
Mobo link: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131619
Now when it does this it sais F1 to continue. right now i pressed F1 and its installing windows.
Actually, I looked at the motherboard. It only supports cpu's up to 95w. The 955be is 125w, you need to return the mobo and get another one.
This is your motherboard's supported CPU list. I note that the 955 C3 is not on that list, but other C3 processors are.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=M4A78LT-M LE&product=1
EDIT: looks like it's not supported because of the power draw! There's not a single CPU on that list over 95w!
Next time, look-up the board on Asus's support website. Just copy the model name into their search engine, and the page should come up. On that page is a link to CPUs supported.
should i let it finish installing windows or Not.
Probably not. You're running the processor voltage regulators out-of-spec. It might run today, but it's going to die an early death (and don't even think about overclocking).
This can also void your warranty if you continue, and the board dies.
yeah i shut it down. what do you guys think about selling the 955 c3 and picking up the phenom 945? would it make a huge difference in gaming?
http://www.newegg.com/Product/Produ...cm_re=AMD_Phenom_II_X4-_-19-103-696-_-Product
If you're planning on overclocking, this is the wrong way to go. You don't dance around the problem - you buy a board with a better power system!
Follow gwarren's advice, the return will only cost you $10, so the total with difference for the new board will be $50 out of pocket.
The board he linked definitely supports 955 C3, but you may have to update to the latest BIOS.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=M4A785TD-V EVO&product=1
When you return something to Newegg, they will charge you a restocking fee of 15%. ...
Just an FYI regarding Newegg returns, since I saw that you sold the chip for such a nice price... if you buy the "replacement part" from newegg, you can ask them to waive the restocking fee, and they typically do it as long as you're buying something to replace the item you're returning.
