question about memory
Hazards
ok i have a epox 4g4a+ mobo that supports up to pc2100 memory, if i turn my fsb up too much i get a memory error, prolly cuz the mem is not good for oc'ing is my thought.
i was going to buy some new ram, and i was looking at a few diff corsairs, my question is:
can i put pc2700 or pc3200 in my board and will it just pick it up as pc2100 and give me more headroom for turning up my fsb? and if so which of these do you recommend?
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-401&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-425&depa=0
or
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-498&depa=0
coo, ive just seem some servers that wont pick up memory at all in wierd situations, does anyone have any recommendations on which stick to get? should i still with the base, or spend the extra dough on either of the other 2?
Your motherboard will have no problem running PC2100 or higher. I would get PC3200 so you could use it in later upgrades because its not that much more expensive. I would personally get 1GB of Mushkin PC3200 lvl 1 for around $203 on newegg. Great price for pretty well the best memory money can buy.
