snoopy7548
- Sep 30, 2007
I am building a new computer soon and I want to OC my cpu to ~3.4-3.6ghz. I am going to buy the Intel E6750 and the Gigabyte GA-P35-DS3R motherboard.
I am planning on buying 4gb of RAM and I was originally going to buy 2 sets of 2x1gb Crucial Ballistix DDR2-800. I decided against that since 4 sticks of ram would be putting more strain on the NB and there's no guarantee I'd get 4 matching sticks.
I've been looking at 2x2gb sets of RAM and they don't seem too expensive. DDR2-800 can be bought for around 200-220 dollars (which is my budget for RAM).
But since I am getting the E6750, which has a multiplier of 8x, that would mean my RAM would have to run at 450mhz to achieve a CPU speed of 3.6ghz, right? 3600/8=450.
Well I thought, since 2x2gb don't really overclock well, why not just go with DDR2-1000 or faster RAM? So I wouldn't have to worry about OCing my ram, just my cpu.
Here is the RAM I really want to buy one it is in stock, it just came out:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
But the thing is, the motherboard I chose says it supports DDR2-800 and DDR2-1066 RAM, and the RAM I chose isn't on their supported RAM list. Do you think I could still use it and it would post at DDR2-1000 speeds? Or would I have to select it as DDR2-800 in my BIOS and then OC it to it's normal speed?
