Question about memory bandwidth and clock speed.
strossos
First off, specs:
Asus K8VSE Deluxe
AMD 64 3200+
2x 512 Kingmax 3200 (in slots 1 and 2 of three)
BFG 6800GT
Antec Tru power 430
multitude of harddrives
Here is some of the general problems I have been having, specifics later. I've noticed in alot of the games I play my fps are pretty low compared to other systems. Like in WoW no matter what settings I have (low everything, or ultra high everything) I still get around 30fps, dropping down in open areas and increasing to the 75fps mark in a small area. I have noticed similar things in CS:S, no matter what the settings... 50fps or so, with sudden drops in big firefights, again, thats with either everything on low or with full AA and AF with everything on high.
Running sandra gets me pretty low memory bandwidth scores (1600 or so), and reports my clock as something wierd (258MHz) while cpuz shows me 129MHz.
Better to let the screenshots speak for themselves:
cpuz memory tab
cpuz SPD tab slot1
cpuz SPD tab slot2
cpuz mainboard info tab
cpuz cache tab
cpuz cpu tab
sandra memory bandwidth pg1
sandra memory bandwidth pg2
sandra system summary (memory bus speed)
Okay... sorry for the longish post, but anyone have any ideas about this? I do have the latest bios and via chipset drivers.
correct your FSB settings in the bios, they should be running at 1:1.
That just brought it down to 1300MB/s on sandra, and cpuz reporting freq at 100MHz...
Trying 2:1.
Edit: 2:1 apparently is the same as what I had before, which is 1600MB/s at 258MHz
Looks like your memory is not running anywhere near its specified speed which is 200 Mhz, 400 Mhz DDR. I don't have a 64 system so I'm not too familair with the dividers and such but the problem is somewhere in the BIOS. Check RAM speed, ratio, and dividers.
Bah, damn motherboard manual was wrong... in slots 1 and 2 it didn't run full speed. However 1 and 3 it works just fine.
Well thanks for pointing me in the right direction. :D
