question about media extender
dajaga
hey people. my main htpc is in my living room. i was wondering if its possible to use a media extender for my bedroom and access my tv shows. i will mostly be viewing hd movies thanks dave i will be using wireless internet
some media extenders are picky.. and you said you're using it for HD content..
I have trouble streaming .mkv formats through my 360.. you may have to do some file container re-codes or audio setup or something..
what media extender do you plan on using?
Had the same problem, in the end I decided that I had to rip and decode dvd's into xvid format so I can then use a 360 to view any shows/movies that I have on my WHS.
I thought about using wireless but in the end decided to use ethernet over power -- so far I've had some good results on it, even on HD stuff. I do see some periodic pausing, which is a little annoying but for now I've decided to live with it; since I'm too lazy to just start the project of running ethernet around the house.
