question about making recovery disks
if i make a recovery disk, it will only have windows xp in it or all those craps that i downloaded?
Let me be the first ... WTF are you talking about :confused:
...craps that you downloaded.. do you mean service packs.. security updates,, gay porn?
You need to give us more information. What process are you using to make the recovery disks?
I prefer using Ghost. I burn the image to a bootable DVD that runs ghost, and let's me restore the image. I get a full restore...XP, apps, files, etc.
Recovery disks will only allow you to run ASR which will restore critical system files if you can't boot your computer. It is not a method of backing up your data.
