Question about Logitech G7 cordless mouse
twitchy10
With the G7, can you just plug the usb dongle strait into the usb ports on your computer and use it wirelessly or do you have to use it in conjunction with the battery charging station?
you can plug the dongle into the usb port and it works. So it is portable. The station is really for charging the additional battery, but you can plug the dongle into that also..
thanks
