The gromac core has dynamic load balancing. Then there is the affinity wrapper the 6.31 folding client asks whether you want to use, and finally there is the Kraken.
Is there an optimum set of affinity wrappers and load balancers to use for a Supermicro 4P running 12.04 LTS with NUMA enabled?
I thought I'd test each option, but the load balancing of the Gromacs core, can't be shut off, afaik. The only option then is either to use the Kraken, or not.
Is it better to run the Kraken, even though the Gromacs core has Dynamic Load Balancing?
And as always, thanks to Musky, Tear, and all the [H]orde, for your work making folding, a bit faster and easier.
