Setzer777
- Sep 9, 2005
So, I've decided to spend a little extra on my case and get a Lian Li. I've heard really good things about them and they appear to be a good quality case. I was wondering if their cases support Micro-ATX motherboards? I was checking out their selection @ Newegg.com and noticed that none of their cases mentioned M-ATX compatibility. Initially my board is going to be an M-ATX and want to make sure their case will work before I purchase it.
Second question -- I was checking out this case....
LIAN LI PC-G50B
I really like how the USB, Firewire ports are on the top because the case would be placed in one of those desks that has a cabinet on the bottom which was designed to hold PC cases. The only thing I really don't like is the lay-out on the inside and how short it is - 15". It's kind of small for a "mid-tower" atx case. It's even shorter than my current Antec Sonata case. Does Lian Li make a taller version of this case with the ports on the top? Also, do any of you have experience with this case and if so what is your opinion of this case? I really didn't want to go over $100 for a case because I have $200 total to spend on a PSU and a Case. I know my options are limited with that amount -- I saw a couple of other Lian Li cases that were $110 but they put the ports right at the bottom *sigh*. Anyways, I would appreciate any help you all could offer.
LIAN LI PC-G50B
