question about intel burn test and gflops, 2 overclocks
Dutt1113
I have a question about running intel burn test on my i7. I overclocked my 930 to 4.13ghz and i ran 10 runs of intel burn test on maximum stress with 8 threads and got gflops of 55.9 and 56 with result numbers of like 2.98 e-002. I tried bumping vcore voltage 1 notch to 1.35625 and running 4.2ghz. Now i am getting gflops of 55.2 +/- 0.1 and results of 3.154e-002. The only thing different is the second test was very high stress instead of maximum because it wouldnt let me for some reason it said couldnt test all available memory pick lower stress. Does this mean my slightly lower overclock is actually faster? The linpack results didnt vary for both and both passed so what gives. I dont understand. Thanks
I don't really understand what you're asking. Linpack isn't really a meaningful performance benchmark. It's primarily a stress test. If your temperatures didn't go crazy and it didn't fail, then its fine. For gauging performance between overclocks, run some actual apps or games, record your results, then do it again with a different clock speed. Though you're not likely to see a measurable difference between 4.13GHz and 4.2.
Nope, the higher the stress level you pick on IBT, the higher the gflops it will report.
IBT shows the free RAM and what is required for each specific test.
Make sure you let the computer finish booting up (no more hdd action) before you try to run the max stress test.
The more memory you have the longer the cpu will be stressed before a brief rest period.Use the custom options with Intel burn test.
