As long as they're not getting in the way of air flow, or they're bare wires.was wondering if cables touching the heatsink is a bad thing?
If they affect air flow, I guess. You can easily unbend them though.and if bent fins are bad?
Sounds like its motherboard controlled, or you're using a Fanmate. Either change the settings (program, or BIOS), or remove the Fanmate/turn it up.and also how do you change fanspeed for this? speedfan shows it only running at 400rpm and I can't change it through speedfan =\
