Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
the ones available thru autozone are usually anywhere from $17 - $250. most are in the $17-$30 range.
chevettes cores, caprice cores, bonneville cores are all under $20.
$250 is prolly not the most expensive but it is the most expensive that I have ran into -- and h311 no, I didn't buy it. If I wanted to spend $250 for a rad, I'd get that big honkin' mirror-finished F1.
you could probably find them cheaper than $17 if you looked but you might end up with a leaky core...
