Question about HD 4670 (from wiki)
Mad_CatMk2
This page, http://en.wikipedia.org/wiki/Comparison_of_ATI_graphics_processing_units, shows some information of the HD 4670.
I find it interesting that the HD 4670 has extremely similar specifications compared to the HD 3870. The only difference I notice is the different 'config cores'.
Question is, if these specs are true, is ATI looking to really take the mid-range market using the HD 4670 with a low price point and the performance of the HD 3870?
The 4670 may be the 3870 itself. A simple renaming and price drop. There's no need to make an RV770-based chip and disable a bunch of SPs when you can just make an RV670.
Yeah more than likely the 38xx series will end up being renamed as somewhere in the 4xxx series.
If that's the case, damned scary it is to imagine a pretty darn powerful 'mid-range' card for about $100-$150.
No, the 4670 is MUCH likelier to be a new chip.
They improved quite a lot of stuff (esp AA) and it's worth putting some into a new chip. Also, 24 TMUs = easier sweep over 9600GT at last for the same pricing.
