K, heres the deal. I need another drive, I need it to be sata 150. I found one I was happy with(click here-- http://www.bestbuy.com/site/olspage...CategoryId=pcmcat33200050001&id=1097580128775)
The model number states |Model: WD1600JSRTL|, so with the model break down in the sticky..
Western Digital
WDx0ab
WD-160gb (code puts another 0 here)J- means 8mb bufferS-means SATA 3.0RTL
WD stands for Western Digital
x = the capacity of the drive in GB
WD puts an additional zero after the capacity value
a = buffer size and spindle speed
- B = 2MB 7200RPM
- J = 8MB 7200RPM
- K = 16MB 7200RPM
- G = 8MB 10,000RPM
- S = 8MB 7200RPM RAID Edition
- Y = 16MB 7200RPM RAID Edition 2
b = interface of the drive
- B = PATA
- D = 1.5 gbps SATA
- R = 1.5 gbps SATA w/ NCQ
- S = 3 gbps SATA
The best buy states that the drive is a SATA 150 drive, yet the code says its a SATA 3.0? Unless the "RTL" part of the code makes it different. Could someone help me here?
Western Digital
WDx0ab
- B = 2MB 7200RPM
- J = 8MB 7200RPM
- K = 16MB 7200RPM
- G = 8MB 10,000RPM
- B = PATA
- D = 1.5 gbps SATA
- S = 3 gbps SATA
